Torque cone question
oh and it stalled twice also!!
If you're talking the traditional torque cones that go between the head and the header, then there's couple things that come to mind from my personal experience with them.
Torque cones by their design are restrictive and can reduce the flow characteristics of the exhaust. If yours are restrictive enough, the air/fuel mix could be richer than it was before you installed them.
It's extremely important when installing the torque cones that the exhaust gaskets stay in place and not move or crush so they protrude into the flow. If they do impede the flow enough, it usually makes the exhaust sound flat and tinny. I've never seen them bad enough to stall the engine though.
I found that going with 1/4-20 eyebolts (lolipops) near the exit ends of each pipe was a better solution to regaining low end torque than going with the torque cones next to the exhaust ports. By turning the eyebolt and changing its angle with regard to the flow, you can tune how much it restricts the flow and also how it affects the reversionary pulses.
Right now, the Bassani pipes I have are good enough in the low end that they don't need anything else.
I'm not familiar with the PC-5 so I can't help you there.
I've yet to read any positive comments from people who have tried them. Let us know your results.
Thanks
P.S why do you think that i should remove them??
