Do I need new Cables?
Old Mar 15, 2012 | 02:46 PM
Degraf124's Avatar
Degraf124
4th Gear
Default Do I need new Cables?
I'm thinking about getting the Harley Davidson mini ape for my 2007 nightster. I know I'll have to get a longer brake line but do I need to get anything else or will all the other stock cables work? Thanks in advance for all comments.
Old Mar 15, 2012 | 03:02 PM
IamDiabolical's Avatar
IamDiabolical
I'm looking to get apes on mine (rather large ones) so I've looked into it, from trauling youtube and that i think if you only want mini 10" narrow apes you can use the stock cables but if you want wider apes probably not.
If i wanted say 10" apes id just buy em, try to fit them and if i need longer cables order them.
Just a note, my friend has an iron and his stock bars where a lot shorter than mine, so the nightster does have longer cables than the iron, he's fitting drag bars on his and because they are much wider he has had to get an extended cable kit, dare i say drag bars would just bolt straight onto a nightster....
Old Mar 15, 2012 | 03:33 PM
Superfly3176's Avatar
Superfly3176
My bet is yes, you're correct. My Keystones + Riser extensions are 10" from the triple tree. I needed a new brake line everything else was okay. I tried doing the same and using the stock 42" cable and it was too short. Ended up ordering a 46" from magnum shielding and it fits great.
Retsthgineht
Jan 16, 2015 09:39 PM
robosmurf
Jul 2, 2012 10:55 AM
OWTKAST cpt
May 26, 2010 10:57 PM
MiNightster85
Apr 20, 2009 12:32 PM
Nightster_Reaper
Jul 11, 2008 03:19 PM
