Help ID part
Old Mar 31, 2012 | 09:42 AM
capttxrngr's Avatar
capttxrngr
Default Help ID part
Howdy, doing some work on my wife's Sportster. Tracked down the light wiring under the seat. The red arrows show the wiring module #7 according the the wire diagram in the manual. The yellow arrow is the item I need to ID. The only marking on it is the number 1809. Any ideas? I am wiring up taillights for my wife's Trigg system and will be tapping into the light harness. The bike is a 2008 1200 Custom.
Old Mar 31, 2012 | 10:03 AM
SteveO-ll's Avatar
SteveO-ll
Don't know what a Trigg system is.............Although, that like looks like a brake turn signal module
Old Mar 31, 2012 | 10:04 AM
guitarman023's Avatar
guitarman023
if that's part of the lighting system, it's probably the turn signal relay. It could be your started relay as well. check the colors of the wires running into it and reference that in your manual, that will tell you what it is.
Old Apr 8, 2012 | 04:52 PM
capttxrngr's Avatar
capttxrngr
Default Done!
Turned out to be a run/brake/turn signal module. Took it out since I was putting other wiring in its place. Got everything finished. Had a little issue with the wiring but got it sorted out.
stash13
Electrical/Lighting/Alarm
33
Dec 13, 2022 10:20 AM
izzyryder
15
Feb 23, 2020 09:26 PM
izzyryder
2018+ Softail Models
Apr 26, 2019 12:05 PM
Coach J
Mar 13, 2014 12:55 PM
gvb
Apr 25, 2005 01:24 AM
