License Plate Light?
Old Apr 7, 2012 | 10:53 AM
JimA's Avatar
JimA
Default License Plate Light?
I'm wiring in a LED license plate light into my 95 sportster 1200. it doesn't work. What do I need to make it work?
Old Apr 7, 2012 | 11:01 AM
HERE's Avatar
HERE
Need a little more detail than it doesn't work. Use a test light and make sure you have power to it first. Is the wiring hooked correctly? Etc
Old Apr 7, 2012 | 11:42 AM
JimA's Avatar
JimA
Everything on the bike works. The LED unit is sealed so I can't really hook a test light to the light itself. I tried hooking it up to the running lights, but no go. I see my bike has an accessories fuse, how do I hook into that?
Old Apr 7, 2012 | 11:55 AM
JimA's Avatar
JimA
The plate light works. I touched the ends to the battery and it lit up. So where on a 95 sportster can I hook it up?
Old Apr 7, 2012 | 12:30 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Wrap the active wire around the 15a accessory fuse, and the ground to the ground bolt above the primary.
Old Apr 7, 2012 | 01:20 PM
JimA's Avatar
JimA
thanks
UltraZac
May 29, 2017 05:53 PM
kpb46
Electrical/Lighting/Alarm
May 20, 2016 10:30 AM
Buggz
Jan 23, 2009 09:26 AM
UltraKla$$ic
Apr 25, 2008 10:41 PM
so cal 450
VRSC Models
Apr 2, 2007 10:44 PM
