o-ring bulged out
Old Apr 18, 2012 | 05:21 AM
nadbornik's Avatar
nadbornik
6th Gear
Default o-ring bulged out
the o-ring (number 1 in the attached file) is bulged out allowing oil to leak down outside of head.
What is the process to correct this?
File Type: pdf
Old Apr 18, 2012 | 05:24 AM
nadbornik's Avatar
nadbornik
6th Gear
07 nightster 1200
Old Apr 18, 2012 | 05:29 AM
Iceman24's Avatar
Iceman24
Easy fix...remove cap, replace o-ring & tighten to spec...DON't overtighten!!!
Old Apr 18, 2012 | 06:08 AM
mrfikser's Avatar
mrfikser
I don't think its quite that easy.....as you need to remove the push rod...so, you need to set engine on overlap, open the rocker cover remove the rocker arm assmbly and then remove the push rod cover...it ain't that tough, but you will need a repair manual for the steps to follow and for the torque specs....
Eagle15
Dec 15, 2017 09:07 PM
pesnemesis
Shovelhead
May 6, 2014 08:25 AM
IlDuce
Shovelhead
Sep 28, 2008 03:58 PM
MaxShovel
Shovelhead
Aug 13, 2008 12:19 PM
dritz123
Mar 31, 2007 04:13 PM
