Would These LEDs Work | 02 883C
Old Apr 25, 2012 | 09:11 PM
Voony's Avatar
Voony
Default Would These LEDs Work | 02 883C
Hey guys,
I want to put small LED turn signals on my sporty. Do you think that these would work?
http://www.harrisonspecialties.com/m...ory_Code=MiniB
My questions are:
1) the diameter of the bolt is 3/8". Would that fit? The guy that sells them doesn't know
2) They come with three wires: black, white and red. I know that the black is ground, but how am I suppose to wire this since my turn signals only have two wires?
When I got my new headlight, it had three wires, one of which was an additional running light. I just didn't wire it.
Thanks for your input!
Old Apr 25, 2012 | 10:24 PM
tripn88's Avatar
tripn88
The same ones are cheaper on amazon.com
They should fit no problem.
Old Apr 25, 2012 | 10:29 PM
Voony's Avatar
Voony
Thanks, what about the three wires story?
Old Apr 25, 2012 | 10:32 PM
tripn88's Avatar
tripn88
they would work for runing lights/brake lights but im sure you could use it with just two wires
Robotech's Avatar
Robotech
The third wire will also be for running lights. That would tie into the blue wire in your loom. Just remember you're going to need a load equalizer when you go to LEDs otherwise they will flash rapidly after about three or so flashes like if you had a bulb burned out.
Old Apr 26, 2012 | 01:30 AM
100yr_itch's Avatar
100yr_itch
could you post a link to that load equalizer? I have a set of mirrors that have turn signals in them and do that flashing.I cut the wires off but I think thats an easy re do....
Old Apr 26, 2012 | 06:23 AM
Voony's Avatar
Voony
So I just tie the two wires (white and red) onto the one (pink) I have on my bike and the lights will be able to be used as run/turn/brake lights?
I already have a load equalizer from Kuyakyn that is attached to the run/turn/brake module :-)
sick98
Electrical/Lighting/Alarm
Feb 17, 2014 07:57 AM
roundy
Feb 13, 2012 07:09 AM
blackcrow
Sep 17, 2011 08:01 PM
Rdizzy
Mar 24, 2011 03:31 PM
anubisss
Oct 31, 2008 10:52 AM
