spoke adjustment
Old May 4, 2012 | 05:52 PM
madchemist24's Avatar
madchemist24
Originally Posted by Gpsjr10
The factory service manual gives a pretty good description on truing wheels. It is much easier if you have a balancing/truing stand. Harbor Freight sells one for around $40 I think.
You know I didnt even look at the manual for this action as I was considering farming the work to a mech until folks started making it sound somewhat easy...I'll have to break it out and give a read over ..thx.
Old May 7, 2012 | 08:34 AM
Jackal's Avatar
Jackal
You don't have to use a lift or remove the wheels or anything to get them close enough. If you hear one that sounds scary loose, tighten it up to sound closer to the surrounding spokes, but after done confirm with the zip ties that wheel is still centered and doesn't wobble outward one way or the other. You tighten the spokes opposite the direction you want to pull the wheel to.
silverbullet2006
Nov 30, 2013 08:54 AM
oct1949
Nov 23, 2011 01:31 PM
Gonzy
Wheels/Tires
May 27, 2011 12:08 AM
charrell
Jul 9, 2007 04:47 PM
Dave_E
Jan 23, 2007 09:16 AM
