rivets vs. rivets
Old May 7, 2012 | 06:12 AM
Sportstatler's Avatar
Sportstatler
Default rivets vs. rivets
Is it better to use hd rivets on timing cover plate? I thought a rivet was just a rivet!
Old May 7, 2012 | 06:44 AM
grbrown's Avatar
grbrown
The mandrel head of most ordinary rivets is open at the end that is out of sight when installed. On Harley rivets the head is enclosed in the rivet, hence water proof when installed. This sealed variety are not as widely available as the ordinary type. So if you rivet your cover back on, yes use Harley ones, to keep moisture out of your ignition.
Old May 7, 2012 | 06:58 AM
96roadking's Avatar
96roadking
or you could use stainless, self tapping screws.
Old May 7, 2012 | 05:40 PM
Sportstatler
Thank you very much!
Old May 7, 2012 | 06:16 PM
Scuba10jdl's Avatar
Scuba10jdl
What he said. In my area it is cheaper to just buy them from the dealer unless you go through 50+ because you have to special order them.
Baird
Shovelhead
Aug 2, 2016 10:43 AM
danwoods
Shovelhead
11
Jun 28, 2014 07:50 AM
Rnt77
Feb 22, 2013 09:54 AM
im
EVO
Mar 8, 2007 08:56 PM
98rdking
EVO
Feb 27, 2007 12:08 AM
