Belt to chain conversion.
Old Aug 7, 2012 | 11:37 AM
John Harper's Avatar
John Harper
So that's what it looks like all clean and new! Looks great, any way you can get rid of that lower beltguard? What chain lube did you go with?
John
Old Aug 7, 2012 | 03:28 PM
SportyPig's Avatar
SportyPig
Originally Posted by trainman123
Done!!! List of parts used.
(1) PBI 283-25T transmission sprocket with .500" offset.
(1) PBI 2073 60T flat sprocket.
(1) MotoParts 530 -120 O Ring Chain.
(1) Cycle Parts for less DS1201-0600 1/2" rear spacer.
(5) Five Fastenal 7/16-14 X 2 1/4 long Grade 8 Hex head Bolts.
(1) Tube of Red Locktite.
For a grand total of about $240.00 for parts including shipping.
Some people have asked me: isn't that a step backwards? My reply is that I just want
to put the SPORT back into my Sportster! I also do some off road riding so this was a
logical choice.
<edited>
Oh...never mind. You got the look you want, which we all know is the only thing important.
Old Aug 8, 2012 | 12:42 AM
rickss69's Avatar
rickss69
The only really good reason for a belt to chain swap is unlimited selection of overall ratios...the rest is purely cosmetic to most user's. If I had a choice I would still be running a belt.
Old Aug 8, 2012 | 07:25 AM
run1fsr's Avatar
run1fsr
Hey Rick ... very cool set-up !!
Old Aug 9, 2012 | 09:54 PM
trainman123's Avatar
trainman123
Originally Posted by IBGary
I've done that with at least two chains. I've also had the drive shaft u joint go bad resulting in a tow truck.
My BMW u joints went bad at about 30k, chains are good for half that if your lucky. I have 25k on my belt and a clean rear wheel and I don't carry a can of oil.
Maybe it's the way you ride your bikes. As you can see I baby mine and have never lost a rear chain. This photo was taken 40 years ago.
Old Aug 9, 2012 | 09:58 PM
trainman123
John
Champion Chain Lube.
Old Aug 10, 2012 | 06:07 AM
JonFMJ's Avatar
JonFMJ
Pretty bitchin, been thinking about doing a conversion. Just wasn't ballsy enough to start buying parts haha. Does it fit under all the covers? And was it super hard?
Old Aug 10, 2012 | 07:13 AM
trainman123
If you have an 06 or newer XL you will need to run a 25/26T trany sprocket to clear the passenger peg bosses on frame. Wide tires requires bigger offsets. I used the 1/2" offset to put the center of the chain to about the same as the belt. Also I am using stock width rear tire. You should keep an eye on the bottom mounting boss of the sprocket cover. It is pretty close and might rub when chain brakes in. You might have to remove some metal for clearance.
http://s800.photobucket.com/user/tra...N2629.jpg.html
98hotrodfatboy
EVO
Sep 16, 2015 05:18 AM
mike_oh
Jun 3, 2012 05:50 PM
HDCrossbones09
Mar 16, 2012 01:34 PM
toxicstang99
Mar 16, 2011 10:30 PM
DGFIRONWORKS
Apr 11, 2006 10:58 AM
