X14iED Install
Old May 19, 2012 | 06:09 PM
adam9604's Avatar
adam9604
Default X14iED Install
Just installed them on a 08 Nightster with HD heavy breather and V&H short shots no baffles. Is there a learning period for them and the computer? Sometimes it runs really good and then at low RPM in any gear it stumbles and wants to die, bucks, etc.
Thanks for any help.
Old May 19, 2012 | 06:25 PM
sioux565's Avatar
sioux565
Some say it takes a hundred miles or so to adjust. Not sure how true that is!
If you run your sporty at low RPM in any gear it will buck and and stumble regardless of how your bike is set up. The Evo's like to be ran at mid-high RPM's.
Old May 19, 2012 | 06:32 PM
adam9604's Avatar
adam9604
O ya...I just replaced a fuelpak with ViEDs....it's just worse than what it was with the fuelpak
Old May 19, 2012 | 07:31 PM
sioux565's Avatar
sioux565
That's strange. Any of the Nightrider products should help, not make the bike run worse. Are you sure you are not lugging the engine in too high of a gear?
cajun1957a
Apr 15, 2020 11:41 AM
goobs
May 19, 2019 01:36 PM
Synstars
Aug 15, 2016 03:51 PM
IrishGirl329
May 22, 2012 08:46 AM
spalmer1214
May 20, 2012 01:07 AM
