Help!!!
Old Jan 7, 2007 | 01:12 PM
Thumper26's Avatar
Thumper26
Default RE: Help!!!
The Sear's screw extractors are for the birds![:@]
Old Jan 7, 2007 | 09:10 PM
04XL1200C's Avatar
04XL1200C
Default RE: Help!!!
I only use the Snap-On brand Easy-Outs and the companion set Screw Extractors. I have found that the Easy-Outs work better than the Screw Extractors. That's why I suggested using the Easy-Outs.
Old Jan 7, 2007 | 09:14 PM
wannahdawg's Avatar
wannahdawg
Default RE: Help!!!
yeah PB blaster is a miracle. and i also agree that easy out is the better choice.
later,
wanna
Old Jan 7, 2007 | 09:24 PM
dsuppa's Avatar
dsuppa
Default RE: Help!!!
where can I get PB and the Easy out stuff? Home Depot/Loews/Pep Boys?
Old Jan 7, 2007 | 09:57 PM
2QK4U2C's Avatar
2QK4U2C
Default RE: Help!!!
I know this might sound a little easy but.....since you were installing it and not removing it when it broke, there should be no pressure on the bolt. Can you/did you try and stick a small standard screwdriver in thereand try to catch a ridge from where the bolt broke and spin it out? Worth a shot unless you put some locktite on it.
Dave
Old Jan 7, 2007 | 10:13 PM
wannahdawg's Avatar
wannahdawg
Default RE: Help!!!
PB Blaster you can find at autozone or advance auto. easy out kit can be found there too but it's the cheap set. i'd go to sears and get a craftsman, lifetime warranty. good luck
wanna
Old Jan 8, 2007 | 12:05 AM
AF FSgt's Avatar
AF FSgt
Default RE: Help!!!
If you end up using an easy out -- DO NOT USE THE INSANE STRENGTH!!! (What does an easy out sound like when it breaks in the broken screw? Ans. Oh S--T!!!!). If an easy out won't do it you will have to drill out the screw entirely. Be sure to follow up the threads with the correct tap. If the hole ends up over sized/loose then a helicoil (thread insert) is your next step.
Lots of oil when drilling and tapping is in order.
Before I became a First Sergeant I spent my time as an aircraft machinist. Had lots of experience with this situation.
Take your time. Best of luck
Old Jan 8, 2007 | 01:18 AM
Wolhar's Avatar
Wolhar
Default RE: Help!!!
lookin at this again, I believe you can get the Lever off, shouldn't be any pressure holding it together, this will make it easier to get the bolt out, the hole goes all the way thru the lever so you can "drill thru" with no problems. And like 2quick said it may turn out.
Old Jan 8, 2007 | 10:07 AM
dsuppa's Avatar
dsuppa
Default RE: Help!!!
Tried pulling the lever off but it won't budge, theres a groove in there where the bolt sits in that looks like it is holding it in place and only the head of the bolt popped off the rest is still in there.
Old Jan 9, 2007 | 09:56 PM
dsuppa's Avatar
dsuppa
Default RE: Help!!!
****** thanks man that worked like a charm less than 15 minutes and the headless screw came out like butter!!
