Starter problems
Old Jun 7, 2012 | 10:15 AM
051200C's Avatar
051200C
5th Gear
Default Starter problems
I am new to owning a motorcycle but have a pretty good bit of background on workin on cars... I have a 05 1200C and I have only had it about 2 weeks now the starter won't turn the motor over I can hear the bendix engaging but nothing after that... Just wanting to see what yal think. I have put 700 bucks into it for tires and belt and want to make sure I am replacing the right part so I don't throw all kinds of green in this for one simple problem.
Thanks in advance
Old Jun 7, 2012 | 10:58 AM
cHarley's Avatar
cHarley
Is the starter just clicking or can you hear it whining?
How many miles on the bike?
How old is the battery?
Is the headlight still BRIGHT when you hit the start button?
Old Jun 7, 2012 | 11:13 AM
051200C's Avatar
051200C
5th Gear
It is just clicking... I have been noticing that when I try and start it that it will turn over until it hits compression then it will pause for a second Like it is struggling to turn it over, then it fires up but now nothing
It has 13,500 miles and not sure for the battery or head light haven't looked at them yet got on it this mourning to ride to work and it wouldn't crank
Old Jun 7, 2012 | 11:50 AM
cHarley's Avatar
cHarley
The first thing you need to check is the battery, it sounds like it's dead. If the battery is the original, it's overdue for replacement.
Also check that the connections on BOTH ends of BOTH battery cables are clean and tight.
Old Jun 7, 2012 | 12:01 PM
sixty4nhalf's Avatar
sixty4nhalf
I would have to say the battery as well.... Give it a good slow charge, if it still does it a few days after riding replace, add a battery tender to it as well to keep it maintained properly. I wouldn't go out and buy a cheep one though you don't want to "boil" the liquid out of it when your not using it for a while.
Old Jun 7, 2012 | 12:12 PM
Scaredofrain's Avatar
Scaredofrain
Check the level of the battery before charging. Sporty's batteries tend to get hot and loose their level rather fast.
Old Jun 7, 2012 | 12:30 PM
cHarley's Avatar
cHarley
Unless it was replaced with an aftermarket battery, his 05 should have a maintenance free (sealed) battery.
Old Jun 7, 2012 | 01:33 PM
051200C's Avatar
051200C
5th Gear
Thanks for the info guys. I'll check on the battery when I get home and post what I find out
Old Jun 7, 2012 | 07:12 PM
051200C's Avatar
051200C
5th Gear
Okay just took the battery out and got it checked and it's good... Battery was purchased 06/2010...just wondering could tapping the starter maybe jar something loose like in a car?
Old Jun 7, 2012 | 07:34 PM
051200C's Avatar
051200C
5th Gear
Okay she starts right up now took the battery out and reinstalled it and its good my guess is a loose connection the negative bolt was finger tight
raanan shenhav
Electrical/Lighting/Alarm
May 23, 2017 07:41 PM
bugzapper
Aug 30, 2014 12:01 PM
TwincamJim03
Jul 7, 2013 11:28 AM
'75 Chop
Ironhead
23
Mar 2, 2009 05:28 AM
djprey
General Topics/Tech Tips
Jun 21, 2007 06:22 PM
