So my 03 Softail has been having trouble starting.. It starts but is slow to do so... My battery is not yet a year old, The cables are tight and it happens when cold or when warm... I'm wondering if my starter relay is going bad... The bike only has 19k on the odometer.. Any other ideas??
I'd think it's the battery.
You could try using jumper cables to see if the bike does crank faster or you could just have the battery tested.
A battery is much cheaper and easier to replace than the starter.
You could try using jumper cables to see if the bike does crank faster .
If it turns out it's the battery, get a trickle charger for your new one. It will make your battery last longer. WalMart has a decent charger for about 20 dollars.
