OK another NOOB question.
Old Jun 12, 2012 | 11:07 PM
Falcon195's Avatar
Falcon195
Default OK another NOOB question.
When coming on and off the throttle on my 1200C at mostly slower speeds I feel and hear what I perceive as gear backlash cluck noise.
At higher speed or RPMs it doesn't seem to be a issue.
I think I am hearing normal geabox noise and possibly not having the engine rev's up where they should be.
Should I hear gear backlash clunk in this situation.
BTW the 1000 service was just performed a couple days ago so the primary chain adjustment should be good.
Old Jun 12, 2012 | 11:46 PM
CanuckSporty's Avatar
CanuckSporty
Sounds like a loose primary chain. Seems strange that it would be loose if you just had a service, but if it was at a dealership maybe not.
You can remove the primary inspection cover and check the slack pretty easily, I see in your sig that you have the manual.
Old Jun 13, 2012 | 03:28 AM
mreed's Avatar
mreed
or you're simply too low on the rpm's.
Old Jun 13, 2012 | 04:17 AM
Harryinny's Avatar
Harryinny
I get the same noise, While cruising around in the lower gears i give the bike some throttle kind of in bursts and get a clunk sounding like its from the front of the bike. Its the same if im holding clutch in to cruise after getting up another 10 MPH then when i let the clutch out again at same speed i started from i get a clunk. Same when downshifting, which is less of an issue seeing i rarely do so when comeing to a stop(ill gear down but not engage the clutch until maybe 1st gear before the stop.)
Old Jun 13, 2012 | 07:39 AM
XL50#674's Avatar
XL50#674
I have had 2 sports and they never did what the OP is talking about. The chain might be a bit loose, but they should have checked and or serviced it at the 1K service.
Old Jun 13, 2012 | 02:47 PM
a40nabowl's Avatar
a40nabowl
Stage II
Hello
Old Jun 13, 2012 | 03:32 PM
mreed's Avatar
mreed
Lol...I will email you. Welcome to the forum.
Old Jun 13, 2012 | 03:37 PM
SportyPig's Avatar
SportyPig
Sounds like a loose primary chain. Don't expect maintenance service at a Harley dealer to be worth the premium price you pay.
Old Jun 15, 2012 | 06:21 PM
Falcon195's Avatar
Falcon195
Well i have had three Harley techs ride and check out the bike and they all said the same thing.
NORMAL and quit worrying about the noise and ride the sucker.
Now I know why everyone recommends loud mufflers or pipes.
They don't want you to hear all the NORMAL noise.
Old Jun 15, 2012 | 07:13 PM
Zimbob's Avatar
Zimbob
Quit lugging it. Run the RPM's up some and that noise will go away.
