Last night I unbolted my shocks, removed my rear turn signals and the fender rail covers. Then I put the covers back on, and bolted the shocks back on (I did not add new turn signals).
This morning I noticed that the front and back screws that hold the fender rail cover onto the fender touch the tire. I can't even slide a pen in between.
I wonder if I could have tightened the covers screws too tight and slightly squeezed the fender inward? What do you guys think?
Insufficient information - No year or bike model given
Are you sure you didn't get the screws mixed up? Guessing 04 or later....
The rear screws (both sides) are 1-3/8"
The front screws (both sides) are 1-3/4"
+1 Something didn't get put back right.
Tire touching but a pen wont fit?
You're missing something. Better go back and re-trace what you did. Remember, if you removed something that was bolted there, you'll need to either replace it with something same thickness or get shorter bolts.
I went back and undid everything. I forgot two washers on two of the fender bolts!!! One one side there is 1/2" and on the other 1/4" ish between the fender and the tire...I wonder why there is such a difference. But I do hope that's enough clearance now :-)
