Bit 'o rust
Old Jun 13, 2012 | 03:27 PM
Superfly3176's Avatar
Superfly3176
Default Bit 'o rust
So I was looking under the bike the other day. Don't even remember why but I noticed some of the paint on the frame peeling and rust forming underneath. It doesn't seem to be anything too serious, but I don't want it to get out of hand. What can I do to stop it from getting worse/spreading?
Old Jun 13, 2012 | 04:24 PM
InsomniaInc's Avatar
InsomniaInc
If it's out of site you could clean it and give it a quick rattle can job. I stripped all the paint off my tank and I use "Boeshield T9" to prevent rust... works great but you will have to apply some every couple weeks or so.
Old Jun 13, 2012 | 04:30 PM
Knights2TheEnd's Avatar
Knights2TheEnd
Rattle can? Your gunna get paint all over your chrome... if the rust is bad than use a wire brush to get rid or it and then sand it with 180, clean it with alcohol, and paint it with a brush with oil based paint, give it two coats and your good, brand new.. If it isn't bad, sand it alittle, clean it, and paint
Old Jun 13, 2012 | 04:33 PM
Knights2TheEnd
When your painting with oil based paints either make sure u dont get it in u or wear gloves cuz that stuff stays on u like sap from a tree.. Ull never get it off with soap and water or a sand block, ull need some paint thinner
Old Jun 13, 2012 | 04:54 PM
InsomniaInc
Well, it would require masking the rest of the bike, which actually isn't that hard if you use some big old towels or contractor's paper, but yes a brush would be easier.
Old Jun 13, 2012 | 05:10 PM
cHarley's Avatar
cHarley
For painting small areas of the frame, I would use black Epoxy Appliance paint, it produces a much harder finish than enamel paint. You can get it at most hardware stores in a rattle can.
You can always spray the paint into a container and then brush it on if masking for spraying is a problem.
Old Jun 13, 2012 | 09:22 PM
ntg433's Avatar
ntg433
Why not give Naval Jelly a try? Wally's sells it for cheap. Just brush it on and it converts the rust to a hard paintable surface. Just make sure the surface is grease free and lightly wire-brushed.
Drea
Powdercoat & Paint
May 24, 2015 10:01 AM
STN
Powdercoat & Paint
Jan 11, 2015 09:14 PM
Mr.Softy
Sep 21, 2013 03:17 PM
schultzy60
Jun 20, 2010 09:38 PM
harley1969
Feb 26, 2008 09:38 AM
