How much oil do you add between changes
Old Jun 14, 2012 | 10:23 PM
Mich's Avatar
Mich
Default How much oil do you add between changes
I am wondering how much oil you guys add to your reservoirs between oil changes to keep it at a consistent level on the dipstick between changes.
I find the level on my dipstick is a little bit lower every few hundred km and I need to add some to keep it 1/4 inch above the low mark every 1000 km or so.
Old Jun 14, 2012 | 10:25 PM
rmeg08's Avatar
rmeg08
Nothing, always good.
Old Jun 14, 2012 | 10:51 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
I've never added oil between changes.
Old Jun 14, 2012 | 11:06 PM
wanabe's Avatar
wanabe
if i ever have to add any its not much...
Old Jun 14, 2012 | 11:09 PM
Shredding rubber's Avatar
Shredding rubber
I haven't ever had to add any. Harley states that 1 quart every 1000 miles is acceptable consumption if you can believe that. If I lost a quart every 1000 miles I would tear it apart to find the hole.
So if your under that Harley says it's fine.
When you think about it though these bikes get insanely hot. I would assume the motor would just vaporize oil or turn it into mud. But they seem to do alright.
Old Jun 14, 2012 | 11:50 PM
Deucedog's Avatar
Deucedog
I've never had to add oil, even after long, fast rides on HOT days.
sioux565's Avatar
sioux565
I've never had to add more than a whole quart between changes. If I ever had to, then I would be concerned.
Old Jun 15, 2012 | 12:00 AM
Sikk50's Avatar
Sikk50
I put in two and a half quarts when I do an oil change. The other half I add a little bit of intermittently when ever the mood strikes me right.
Old Jun 15, 2012 | 12:08 AM
Curt1953's Avatar
Curt1953
Maybe 1/4 quart here.
Old Jun 15, 2012 | 05:27 AM
Harryinny's Avatar
Harryinny
None yet, Mine has stayed at the halfway mark between min and max on the stick. I hope it stays that way lol. Specially after i switch to Syn soon. That stuff is expensive as hell.
