Mind boggles!!!!!!
Old Jun 21, 2012 | 03:38 PM
ShovelyJoe's Avatar
ShovelyJoe
Stage II
Default Mind boggles!!!!!!
So....
Using a five pole ignition switch.
Feed from battery and feed from acc's no problem.
Starter lead connected to ign creates continuous spark on the plugs but once the engine is running starter motor keeps running.
Stater lead connected to st only creates spark at the end, once I have let go of the key - nothing while I am turning the key.
So everything is working, spark plugs, starter motor, battery, etc etc but can't work out how to correctly wire it so it all works a the same time.
If you can solve my riddle you will have a new best friend for life ; )
Cheers
Old Jun 21, 2012 | 03:56 PM
Rog48's Avatar
Rog48
On your John Deere tractor? If its a diesel it doesnt have a spark.
Old Jun 21, 2012 | 04:22 PM
ShovelyJoe's Avatar
ShovelyJoe
Stage II
Model might have helped : ) 2004 evo which has been chopped.
texashillcountry
EVO
15
Oct 2, 2018 03:37 PM
frankbraeside
Jan 20, 2015 01:04 PM
surgeon general
Sep 23, 2014 12:46 PM
Scubamike
Oct 13, 2011 10:09 PM
Snowturtle
Shovelhead
Aug 24, 2009 07:40 PM
