Weird vibration.. Loose pipe
Old Jun 29, 2012 | 01:13 PM
hfp3030's Avatar
hfp3030
Default Weird vibration.. Loose pipe
So on my way to work today I noticed a weird vibration at high speeds.. Although I ride an Iron 883, after I replaced my front sprocket for a 29T, the vibrations at high speed were considerably reduced.. So it wasn't too hard to notice today.
When I got to work I did a quick look around to see what could be causing the vibration, and didn't seen anything (at first I didn't think it could be the pipes so I didn't even check them).. Later while taking a smoke break, for some reason, I decided to check the pipes.. and sure enough, one of the pipes was lose and the 2 bolts that attach the pipe to the bracket are gone..
I'm happy that I found the source of the weird vibration, but now I'm worried that I won't make it home before the pipe will just fall off on the freeway.. I'm thinking about using some zip-ties where the bolts go on the bracket, but I don't know how much they will last before just melting off..
Any suggestions ?
Thanks.
Old Jun 29, 2012 | 01:16 PM
AustinXL's Avatar
AustinXL
Wouldnt use zip ties, you're correct, they'll melt.... Maybe use safety wire or something just so it doesnt vibrate off...
I'm assuming you're talking about the 2 bolts that attach the muffler to the crossover? The muffler is still clamped to the head pipe so I dont think you'll lose it or anything, just get it home and get her fixed.
Old Jun 29, 2012 | 01:17 PM
AustinXL's Avatar
AustinXL
Old Jun 29, 2012 | 01:26 PM
hfp3030's Avatar
hfp3030
Maybe a shoelace just to hold the pipe in place ?.. it's like a 20 mins ride home.
Old Jun 29, 2012 | 01:27 PM
hfp3030's Avatar
hfp3030
Maybe a shoelace just to hold the pipe in place till I get home?.. it's just like a 20 mins ride.
Old Jun 29, 2012 | 01:49 PM
AustinXL's Avatar
AustinXL
If its just the muffler I highly doubt you'll lose it, those clamps are usually on there pretty good where it meets the head pipe.
Old Nov 4, 2012 | 12:03 AM
Dual-Linkerts's Avatar
Dual-Linkerts
Yet another vibration issue huh.
ryda
Dec 4, 2017 09:43 PM
SiggerTX
Aug 21, 2016 02:10 PM
IceColdDeluxe
May 7, 2015 01:38 PM
TedMan
Feb 24, 2012 04:23 PM
Wally
Apr 29, 2007 10:31 AM
