Voltage Regulator Recall
A simple letter stating the problem and the effort they are making to fulfill the orders isn't all that difficult to do.
I see no effort on their part to explain it other than a litle blurb.
These problems are not unique to the Motorcycle world so maybe they should take a cue from the Auto Makers.
I shouldn't have to find out about this from a non affiliated Internet Forum.
As I posted 2.5 weeks ago here in a thread on 6/12/12, this is a Service Bulletin.
If you read the Service Bulletin, specifically the section labeled "Customer Notification", the reason you have not yet been notified is explained, and IMO, was a smart choice on the MoCo's part.
Much like any other manufacturer in this situation, mass notification is being delayed to allow the dealers to service critical needs (broken bikes) first.
This problem involves a high failure rate part, but it is not currently affecting every bike with this part. As can be seen on these forums, many Harleys sold see relatively low annual mileage and many of these may not experience a regulator issue in the near term, if at all.
Had the MoCo immediately flooded the customer base with Service Bulletin notifications on this issue, YOU would likely not have received such a quick turn around on your repair. Your bike would likely still be sitting in line behind a flock of other bikes that were brought in because of the notification, but as yet were not experiencing a problem. And, the regulator you needed would have likely been Out Of Stock, because it was used on a bike that didn't have a current problem, but fell under the notification.
I'm certainly not a great defender of the MoCo and all of their practices, but IMO, this unfortunate problem is being handled about as well as can be expected.
If a bike shuts down in the middle of traffic is that not a safety issue? And you know this problem could very possibly happen.
I'm not asking for them to send out a notification to ALL 2012 Harley owners. They obviously know what bikes are affected and which ones aren't. Those who have registered their VINs on the MoCo website either got a notification or they didn't so that tells me they know EXACTLY what bikes are affected.
As it was the regulator I needed was out of stock when I took it in and they had to rob it from elsewhere.
There are better ways to handle this and I personally think they did poorly at it.
Agree or disagree with me but that's how I see it.
So if that is the case, flagging this as non safety issue is a little bit on the easy side.
OTOH if the bike just does not restart after being shut down, that it is clearly a different issue.
About the cycle electric thing, you are saying that even not faulty HD VRs, aren't that great, and have high failure rate anyway?
I took a look at their web site, and they do not seem to have a fit for a 2012 Sportster.
I got that they are basically mostly the same, modulo different wiring harnesses, right?
Having never taken an HD VR apart, does the wiring harness simply unplug from the VR (hence, it can be reused with the new VR - so you can get a raw VR w/out wiring), or you need to get the full VR plus matching wiring harness?
Here is the difference between the two........
The only way the bike would shut down in the middle of traffic due to the regulator failure, is if the rider chose to ignore the Check Engine and Battery warning lights. Sorry, that would be the operators fault for ignoring the warning. The warning indicates an impending electrical failure.
I've had 3 charging system failures on my Sporty, and in every case it was 10-15 minutes from the time the warning lights appeared till the bike died.
Had there been other bikes ahead of you because of a mass mailed notification, there wouldn't have been anything left for them to rob a part from. You would have been waiting weeks for a part.
