Help
Old Jul 3, 2012 | 05:31 PM
Streetbob Bomber's Avatar
Streetbob Bomber
Default Help
Ok, doings a sporty build 1200N, i have a 21in front wheel off of a soft tail, problem is it doesn't fit obviously, anyone know the best way to get this wheel mounted up, hoping new trees will get it in there...thanks all
Old Jul 3, 2012 | 07:55 PM
HarleyScuba's Avatar
HarleyScuba
Wide Glide conversion kit? Check the axle/bearing size for that 21".
Old Jul 3, 2012 | 08:29 PM
Streetbob Bomber
would a wide glide front end look right on a chopped, bobbed, and slammed sporty?
Old Jul 3, 2012 | 09:22 PM
HarleyScuba
I guess it depends on what you chop, bob or slam.
Bearing sizes have varied over the past 6-10 years. If you plan on reusing your lower legs, you'll need the appropriate bearings for the legs' axle holes. An '07 Nightster has 3/4" bearings in front. It'll make life easier if the Softail hub has 3/4" bearings.
A Google example. This may actually be a mid-glide and it has raked trees, not a cut and raked neck:
Wasta81
Jun 19, 2017 12:49 PM
Todd611
Wheels/Tires
Dec 1, 2013 06:24 AM
Todd611
Nov 30, 2013 09:14 AM
joebotics
Sep 29, 2013 05:16 PM
FatboysFatboy
Wheels/Tires
Nov 27, 2012 09:30 PM
