First thing to remember is that HD "earth" is NEGATIVE ground - opposite Mr. Lucas's positive ground.
I doubt Iceman is old enough to need to worry about remembering that.
Most vehicles that were still using positive ground electrical systems at the time, were switched to negative ground systems by the mid 1950's. The last vehicle I recall still using a positive ground system, was a 1960 Metropolitan Coupe.
If I remember correctly Jaguar still had positive grounds in the late 60's...but the op is probably still to young to remember that...
Well, I took it right down to the frame last night and went over every wire, popped every connector and coated with dielectric grease, then pulled the fuses and did the circuit tester thing. The 30 amp primary fuse showed a ground so now I'm really wondering... Anybody have any more ideas?
It looks like the only things that are connected to the 30 amp MaxiFuse (without going through one of the 15 amp fuses), are the starter relay, the voltage regulator, and the Red wire to the ignition switch.
I'd start disconnecting them one at a time.
I've got a feeling it is the starter relay. There is a loud buzzing noise and a pause prior to the starter rolling over. But if that is the case, why would the battery still be going dead when the bike is off? Would that relay still be feeding power through to the ground even with the key off?
Not if things are working correctly, but obviously they are not. Pull the relay and look for corrosion on the relay contacts.
Pull the relay and see if the drain stops. The relay may or may not be the problem, but you can buy a new one from most auto parts stores for about $5.00.
LOL! Just for reference, the first vehicle I drove was a 1949 Dodge 3 ton grain truck with the positive ground. My 1951 Ford 8N yard tractor is still positive ground...
You've got an 8N? Still 6-volt? I assume no lights? :-)
I spent lots of time as a kid in the seat of one of those runnin' a bush hog and plowin' snow - Great old tractors!
