LA Choppers Outlaw z-bar
They dont actually "taper" - The photo provided makes it seem as if they "taper" because of the angle of the photo. The "taper" is actually the "pullback" so essentially if they are not mounted on the risers "level" then the 'pullback' with actually become a 'taper' .
Hope that makes sense.
On a side note. I have my Outlaw Z-Bars with the original switch housings still internally wired. Only thing they need are the connectors attached to the wires, installation of grips, clutch, and brake, master cylinder and you are good to go.
I paid $250 for the bars plus $600 for the internal wiring and $150 for new switch housings for a new set for my current set up. I'll sell them to you for $400 if you're interested. PM me and I can send you some photos if you want.
