virgin handle bar install
Old Jul 29, 2012 | 10:25 AM
stickystuff's Avatar
stickystuff
Default virgin handle bar install
first time... any tips or tricks removing switches/mounting new grips?
Old Jul 29, 2012 | 10:43 AM
Sp'48'ster's Avatar
Sp'48'ster
Go slowly. Grips and switches will slide off the bars easily, just remove the plate holding the bars in place first then slide off the right side followed by the left. Reinstall the same way your remove the controls
Old Jul 29, 2012 | 10:45 AM
RATROD HOG's Avatar
RATROD HOG
put a towel on gas tank you will thank me later
Old Jul 29, 2012 | 10:58 AM
RedTailChop's Avatar
RedTailChop
Watch both parts of this video.
http://www.google.com/url?sa=t&rct=j...PqIpu6vQj5iLaQ
Old Jul 29, 2012 | 08:24 PM
mjolnir's Avatar
mjolnir
Don't overtighten your clutch cable.
Old Jul 29, 2012 | 08:49 PM
slvdout's Avatar
slvdout
squeeze the brake lever and place a shim in the front...that way when you put it back together you wont break your brakelight switch
Old Jul 29, 2012 | 10:55 PM
edgeofinsanity's Avatar
edgeofinsanity
This...
It doesn't take much of a shim, but you need to clear the brake light switch. I use a zip tie folder over onto itself a couple times. Put it in when you first start, and take it out last.
Old May 26, 2014 | 09:15 PM
nashvegasmatt's Avatar
nashvegasmatt
Originally Posted by edgeofinsanity
This...
reviving an old thread here... but can you expound on this... im about to do the same thing but don't understand why this is important.
Old May 26, 2014 | 09:35 PM
HarleyScuba's Avatar
HarleyScuba
Maybe this'll help:
http://www.harley-davidson.com/en_US...ts/-J00445.pdf
The plunger for the brake switch is inside the switch housing, circled in red, below. The plunger is a tiny piece of plastic, prone to breakage. Installing a shim takes the pressure off the plunger so it doesn't get broken during assembly/dis-assembly. I prefer to put a rubber band or zip-tie around the hand grip, pulling the brake lever towards the hand grip. This relieves the pressure (instead of a shim) and I don't worry about it falling out or forgetting to put it back during re-assembly.
The normal position for the switch is pushed in via a tip manufactured into the brake lever. When you squeeze the brake lever, the switch is released, making the brake light illuminate.
A 2005:
Another pic, the OL's 2004, the plunger (with a tiny rubber boot over it) and lever tip circled in red. I had to squeeze the lever slightly to get this shot:
Old May 26, 2014 | 09:57 PM
elfnyc's Avatar
elfnyc
dont lose them little ferrules when u remove the cables from the throttle
