48 Headlight Bracket
Old Aug 10, 2012 | 01:16 PM
HBRHMR's Avatar
HBRHMR
Default 48 Headlight Bracket
I'm in the middle of doing my bars, chopping the fender, adding springs/struts, and I decided to move my headlight as I wait for various parts to come in.
I could not find a bracket that would accomplish what I wanted to do for the 48; only the eyebrow mounts. Searching the forums I saw one guy make a big rod (didn't like it) and I saw someone else use a 90 degree curved bracket that looked good but I couldn't find one. So, I decided to try my hand at some custom fabrication.
I took some 16 guage steel and on the first one I just freehanded an outline. It's about 4" up, 2" out and 1" wide. Cut it out with a jigsaw and used the first one to trace the second. Then I drilled the holes and took my grinder to the edges to make sure everything could still move. Used a spacer between the headlight tabs on top. Haven't rode with it yet but turned her on and it's pretty solid.
Fairly easy to do so I figured I'd share the process with my fellow 48s. I'm sure it's been done many times but I couldn't find anyone selling one.
Attached Thumbnails 48 Headlight Bracket-388118_741115541470_58202257_n.jpg   48 Headlight Bracket-255369_741115596360_1644306282_n.jpg   48 Headlight Bracket-185893_741115671210_1776211330_n.jpg   48 Headlight Bracket-558353_741853727140_1336173283_n.jpg   48 Headlight Bracket-226250_741853836920_1183064240_n.jpg
Old Aug 10, 2012 | 01:18 PM
HBRHMR's Avatar
HBRHMR
Close up
Attached Thumbnails 48 Headlight Bracket-304824_741853856880_258975750_n.jpg
Old Aug 28, 2012 | 11:49 PM
Newmonster's Avatar
Newmonster
Clean! I like it
Old Aug 29, 2012 | 03:04 AM
Blaven48's Avatar
Blaven48
Looks good. The real test will be when you take it for a ride to see if the vibration is going to make it sag down at all.
grevsucram
Electrical/Lighting/Alarm
Jul 18, 2017 08:10 PM
IronRider72
Mar 28, 2016 11:52 PM
Francois.j
Jan 14, 2013 05:07 AM
joeldenomy
Mar 22, 2012 09:25 PM
Jackal
Mar 19, 2012 03:32 PM
