Changing Fork Oil/Springs
Old Aug 11, 2012 | 09:35 PM
sioux565's Avatar
sioux565
Originally Posted by rickss69
Not sure what year they stopped putting them on the fork legs, but there is a good chance you have no drain screw on your's.
The SM says that it does. I'll have to take a look for my self.
Old Aug 11, 2012 | 09:47 PM
HarleyScuba's Avatar
HarleyScuba
I guess you don't have to take the weight off the front end, but it's highly advisable for making life easier and more safe. I've never done fork work without lifting at least the front.
Check this thread:
https://www.hdforums.com/forum/sport...05-sporty.html
Factory fork oil will come out black when drained with as few as 2000 miles. I'm not sure why. Maybe it's manufacturing residue.
Old Aug 11, 2012 | 10:02 PM
SportyPig's Avatar
SportyPig
Oh, absolutely it's easier. The last 2 times I've changed the fork oil, I have taken the forks completely off the bike. I think that's the only way to get precisely the amount of fork oil you want. No other way to totally drain the forks.
Old Aug 12, 2012 | 06:37 AM
grbrown's Avatar
grbrown
My 2011 doesn't have drain plugs. When buying new springs get them to match your weight. I used RaceTech single-rate and also have a set to go in my Glide. They have a weight/rate guide on their website.
Old Aug 12, 2012 | 07:26 AM
cHarley's Avatar
cHarley
I can see how that works well for for bikes that always run with a fixed weight load, but when rider weight varies from solo to 2up plus luggage, I think a progressive springs are a better option.
Just my 2˘
rickss69's Avatar
rickss69
If you want to end the debate on fork oil, just use ATF...works great and has forever.
Old Aug 12, 2012 | 07:43 AM
grbrown's Avatar
grbrown
Wink
Just my 2˘
Once upon a time I would have agreed! Recently I have undergone a re-education on suspension, hence have single-rate springs to go in my Glide, which I ride both solo and duo.
Old Aug 12, 2012 | 08:01 AM
cHarley's Avatar
cHarley
Yea, but a 200 pound weight change doesn't affect a heavy touring bike like it does a light weight Sporty.
Old Aug 12, 2012 | 08:38 AM
Racer99's Avatar
Racer99
Does anyone have a an idea to the type of fluid and weight of oil to use when you change out the oil?
Old Aug 12, 2012 | 08:41 AM
Racer99's Avatar
Racer99
Here's a great link for the Fork Caps:
https://www.denniskirk.com/282291.sk...utm_medium=cse
