Battery and Fork seal 2005 Sporty
2005 Sportster Custom
Can I get a basic how to for battery removal and install. Looks straight forward but I want to be sure.
Secondly, how difficult is a fork seal job? Or how much should I pay to have it done?
Did not notice the fork leak before I bought it. Slight but it is there.
Thanks in advance...
One hint for the battery: Get a 10MM wrench, and wrap it in electrical tape or dip it in the "liquid tape" so that when it slips off the nut and touches the frame, it doesn't arc and weld the wrench to your bike. :-)
the battery you unbolt the ground cable at engine and then pull out battery and then remove ground bolt at battery,
not bad but a pain in azz,harley drop the ball on that one.
Not too bad of a project, unless you strip the heads on the 6mm socket-head bolts that go up from the bottom into the damper tube. This wasn't the first set of lowers I've swapped out, but for some reason all four (2 sets of legs) got boogered up.
Tie your caliper up with zip ties. Don't let it hang by the hose.
Here's the ez-out I used on the stripped damper rod bolts:
The rubber dust shield (located under the shiney metal cap mentioned below) and c-clip. A lot of times those c-clips are pretty oxidized. Wire brush them clean or get new ones. The oil seal is directly under the c-clip (you can see a brown rust stain from the oxidized c-clip on the seal)
The innerds. That top, black ring is the oil seal (not to be confused with the rubber dust shield that is directly under the shiney metal cap seen here on the right leg)
These sockets work great for the tube cap. Notice the o-ring to prevent scratches and the rounded corners to help prevent cracking the chrome. It's a 1 3/8" socket that's shallow to allow working under your mounted handlebars. I think mine is from Motion Pro ("MP 08-0139" stamped on side) available through Dennis Kirk, Drag Specialties, etc.
How much thread you got before that top nut takes your eye out. It's not terrible, but it is under tension:
Put down card board or newspaper. When you drain the oil, it'll go everywhere unless you pump the leg s-l-o-w. Hold a bucket under it, moving it in motion with the leg, while you pump (assuming your bike has drain screws in the lower legs).
When you're ready to seperate the lower leg from the fork tube, use a slide-hammer type action and they'll pop apart. Start out easy before you get Medieval on it.
After removing the damper rod bolt out of the bottom, I take the fork tubes out of the triple clamps. It's easier (good time for a turn signal relocation). I bought a fork seal driver because I knew I'd be doing more than one set. Years ago, on my old Honda, I used an appropriately sized PVC pipe to set the seals. In addition to new seals, you'll want new upper and lower bushings while you're in there (they last for about 15k-20k miles but I didn't want to do it twice). Get new drain screw crush washers, too. I always get new damper tube screws and their crush washers, even if I don't destroy them getting them out.
Enjoy.
I charge $100 per leg plus parts if I do seals/bushings. If you bring it to me off the bike I'll knock off $25/leg, and if you bring it to me separated to just drive the seals back on I'll charge you $15 bucks.
Service manual is ordered.
Never knew about that socket. NICE!!!
its Jack in a box time and he aint nice.
While those legs are off, you could polish or power coat 'em:
