How do I remove this fitting?
Old Aug 19, 2012 | 02:34 AM
Mcnasby's Avatar
Mcnasby
Default How do I remove this fitting?
The black plastic part of this fitting broke off and apparently now this fitting has been replaced with just a brass L. How do I get the old one out? Bike is a 93 883 sportster.
Old Aug 19, 2012 | 03:04 AM
forever 2 wheels's Avatar
forever 2 wheels
Smile
Mcnasby, I had same issue with 95 Softail carb. Half plastic elbow cracked causing garage to smell of fuel. I removed carb, pulled old piece out with large pair vise grips. Installed new part.
I bought all metal replacement that was standard part many years before factory started using half plastic.
If you feel lucky you could remove carb, take to service writer at HD Dealer and ask how much to R&R parts.
Once you start this project you will need to remember how cables were installed and you may need to replace other pieces that some how become damaged or broken.. I recall having to adjust choke also. Take many pics while at different stages of replacement..Good luck whatever you decide to do..
Heres a pic of my family reunion run in Maryland this year..
Old Aug 19, 2012 | 06:56 AM
xFreebirdx's Avatar
xFreebirdx
Here are some instructions and a place you can get an aftermarket replacement.
http://www.harley-performance.com/ha...uel-elbow.html
CVP Fuel Max Inlet Elbow
http://www.harley-performance.com/fuel-max-inlet.html
Old Aug 19, 2012 | 09:43 AM
Scuba10jdl's Avatar
Scuba10jdl
This is what you want to do. The stock one is prone to breaking.
Bon_Scott
Jul 16, 2015 02:42 PM
enginesludge
Dec 21, 2014 09:16 PM
chckn1952
Exhaust System Topics
May 28, 2012 10:50 AM
oil leak
Ironhead
22
May 2, 2011 09:15 PM
Tim
Apr 10, 2006 09:31 PM
