1200 custom advice
cheers
let me tell you something if you don't change the stock seat on the sportster and go for a sundowner or a mustang you should ride it alone
it is a pain in the *** for the passenger to sit on the stock seat
I bought 5 months ago a 2012 XL 1200 C, mainly to commute to my work, 75 kms to go one way, I ride at 120/130 kph on the highway, the bike is up to the task without any problem, but:
- buy a windshield, a good one which will eliminate the pressure on your neck & chest, and which will avoid any head buffeting. I did buy a H-D quick detachable windshield and certainly don't complain, I had to adapt it to heighten the plastic though.
- if you ride often two up, get anothet seat and a sissy bar.
- if still no comfortable with two up, check the rear suspension.
If you plan to ride really often with two up, I would take a BT, but this is another budget ($$$$).
cheers
That apart, here's my 2 cents (I have a 2011 1200C, mostly stock but now putting on V&H 2-2 exhaust, Airfilter and race tuner).
1) Speed, distance: 70x2kms daily at 110km is a hoot. Even without the mods. Very easily done, and 110kmph is very stable and is in the "zone". I mostly do 4th gear between 85-110, and depending on if its a long stretch, 110 upwards on 5th.
2) Mileage, stability: You will get good mileage (probably around 20-22+ km/l after the 1st service)and very good stability. Even 2-up.
3) Seat/Comfort: Stock seat for me is no problem, even 2-up. I'm about 71kilos and 5'8. Have ridden 2-up people between 55-80kilos and 5'7" - 5'11". With your 80+48 (please do post pics of the 48!) and assuming average height, you will have no problems at those speeds and distances.
I do recommend a sissy bar - the HD medium/small sissybar with pad (see my sig) works very well indeed.
Dont go about modding and swapping seats till you have "ridden-in" and tested the stock.
4) Safety (on bike) - I would recommend that the first "mod" should be a standard HD frame mounted crash guard. Its saved me and the bike recently, so a great investment.
5) Wind protection - I'm a bit torn on this one, and there's no easy answer. Its very windy where I am, and the wind blast gets tiring at sustained 110-120kmph speeds. Dont know how windy it gets there. I would like to have avoided a shield, but am going to try out a compromise. You can check out the National Cycle shields: Deflector DX, Flyscreen and the Tombstone. All are relatively discreet and offer reasonable protection from wind blast for a small price.
6) Bags/luggage - Again, a bit ambivalent (form vs function thing). If you ride 2 up, then if you need a backpack, your OL needs to wear it - so check with her about the whole packrat debate. 1-up for bits n pieces (the odd laptop, drink, sandwich whatever), a backpack can do. Else look for a fork mounted toolbag (strapped on, many options) for the odd geegaw or two, and throw over saddlebags that you can put on or take off asap. I would recommend that you put saddlebag support brackets if you plan on hauling bags though.
7) Personal safety - depends on weather etc, but (through personal experience) I recommend - sturdy riding gloves, sturdy leather or armoured jacket, armoured jeans (eg Hood from the UK), sturdy riding boots with think grippy soles and reinforced toes. Ideally your OL should have a similar outfit too. I have both a 3/4th HD helmet and a pretty expensive Shoei FF helmet. For longer/harder/windier rides, the FF is the better bet.
8) Tires, suspension - Stock fatties from Michelin Scorcher are good enough. Stock suspension for highway and your combined weight can be adjusted on preload settings, so experiment with that.
The 1200C is a great ride for the money. In Scandinavia, due to prohibitive prices, I can manage a Sporty in a budget that would get me into the Softtails. (I still would prefer a Sporty or a Dyna, but thats just me). Dunno about prices in Oz, but you wont go wrong with a 1200C - enough power, looks and rides like a motorcycle, relatively affordable and allows for a ton of both performance and aesthetic mods.
Test ride one if you can. Good luck with your decision.
Cheerio,
A
ALOT of 2 up riding, A DYNA Superglide Custom may be better.
Either way, you will need a windsreen, and some forward controls, or a crash bar with highway pags and some saddlebags will make it easier to live with as a commuter bike.
If you have the coin, a Streetglide will give you everything.
Just my .02
~Joe
