LED assistance
I have a 2011 Iron 883.
So I'm having some issues with LEDs I've installed on my bike and before messing with it any longer I figured I'd take to the forums to see if I could get some help with it.
The issue sorta started when I replaced my stock front turn signals for LEDs, after that my turn signal indicators on my dummy display were always on, and my security system indicator on my speedo would remain on while the bike was running. Shortly there after my alarm stopped working (I have to put in my code every time I start the bike now)
I put up with these problems because everything but the alarm was still functional, the front LEDs worked as turn signals and my dummy display indicators would flash when I used the turn signals.
Last night I decided to replace my stock rear light assembly for LEDs, and now I'm having some more issues..
Running lights and turn signals work fine, my problem is with the brake light. After I use the turn signals, the brake lights stop working on whatever turn signal I used and doesn't work anymore until I turn off the bike. Although the running lights and turn signals continue to work without issue.
I did install a load equalizer, but I don't think it made a difference.
Any help is greatly appreciated,
Thanks!
