Leaking oil from rocker box/shaft screw
Old Sep 13, 2012 | 10:33 AM
marine_hm@hotmail.com's Avatar
Question Leaking oil from rocker box/shaft screw
New issue. Geesh. It seems to never end. Is it common for it to leak from here? Before I start ripping **** apart. Is there an easy fix. I looked at the manual, it suggests taking the rear cylinder and rocker box out together due to tight space. I get it! Couple of weeks ago while fixing electrical issues, I pulled the oil tubes to replace the gaskets. I noticed the oil tubes themself were clogged solid, so I cleaned them up and reinstalled. Probably wasn't leaking at the rocker because it wasn't getting oil at all. Now it's getting oil and leaking.
Would replacing the O-ring do the trick? What about the shim? I don't see how but i'm going to ask first... If I pull the shaft screw, is that going to f-up my valves in any way where they will need readjustment?
Thanks in advance
Attached Thumbnails Leaking oil from rocker box/shaft screw-rocker-plug.jpg   Leaking oil from rocker box/shaft screw-oil-tube.jpg
Old Sep 14, 2012 | 09:30 PM
Anyone? Anyone? I realize it's an older harley and maybe they are just going to leak no-matter-what.
Old Sep 15, 2012 | 12:14 PM
taurussporty's Avatar
taurussporty
3rd Gear
leaking oil from your rocker box especially rear rocker box is very common . they are very prone to leak more so then larger harley engines for some reason. and odds are when you replace the gaskets they will leak again.
Old Sep 15, 2012 | 12:41 PM
John Harper's Avatar
John Harper
Why not ask this question on xlforum.net? There are a lot more folks that know ironheads over there than on this site. Plugged oil lines are never a good thing.
John
Nasty514
May 26, 2018 01:18 PM
jeepett5
Exhaust System Topics
Sep 3, 2013 10:04 PM
NicholasJ234
Oct 2, 2012 05:54 AM
Scudda
EVO
Jul 7, 2012 11:21 AM
bigfish
Ironhead
15
Jul 6, 2006 01:34 PM
