Rocker Cover
Old Oct 2, 2012 | 07:03 AM
CRocks's Avatar
CRocks
Not sure what year yours is, but my '99 back cyclinder was a bear. Make SURE piston TDC compression stroke or it AIN'T comin out. Then when it does, same thing goin in. Anyway, I'd do both cylinders (upper + lower) at the same time. After doin the back, front will take about 30 min.
Old Oct 2, 2012 | 08:37 AM
m3apx's Avatar
m3apx
Dumb question - and I should probably check the service manual before asking - but how do you turn the motor over so that the piston is on the compression stroke to get the clearance to pull the rear cover?
Old Oct 2, 2012 | 09:03 AM
AtkRWC's Avatar
AtkRWC
Jack up the rear wheel. Pull the plugs, put the bike in gear and turn the rear wheel by hand.The service manual will tell you how to find where you want the pistons/stroke for each front or rear heads.
Old Oct 2, 2012 | 09:57 AM
1200Cdriver's Avatar
1200Cdriver
5th gear turns the engine the easiest.
Old Oct 2, 2012 | 04:10 PM
mikedsilva's Avatar
mikedsilva
My 2008 Nightster had this lead about 2 months ago.
I just bought some genuine gaskets and did the rear cylinder only.
So far, everything is bone dry.
Very satisfying to have fixed something myself!
Old Oct 2, 2012 | 07:28 PM
m3apx's Avatar
m3apx
Atkrwc - thanks for the info.
Thund3rbolt
Jul 28, 2019 11:56 AM
daven9113
EVO
Jul 29, 2017 01:51 PM
yzergod
Jun 29, 2014 11:24 AM
rhomer
Sep 7, 2007 09:00 AM
SimonW
Nov 26, 2006 07:38 PM
