Winter projects
Old Jan 26, 2007 | 02:20 AM
SportyPig's Avatar
SportyPig
Default RE: Winter projects
My biggest project is learning how many layers of clothes are needed for the different temps. I've about got it down. Some days I'm over dressed, some I'm under dressed...but I'm getting it zeroed in.
Old Jan 26, 2007 | 10:26 AM
OpenRoad's Avatar
OpenRoad
Just some basic maintenance: brake pads and replace the throttle cables (and remount the tailight so it doesn't keep vibrating loose!).
Old Jan 26, 2007 | 09:16 PM
utz's Avatar
utz
Put on 27"drag bars,relocated front signals,badlander seat,front and rear pegs,oil gauge,progressive 412's,braided throttle,clutch,brake lines.visor headlamp trim,and turn signal lens.Thats about it for this winter or I will have to keep buying the wife things if I buy anymore .She feels if I buy something she should to because she works also.Thats fine with me though.
Old Jan 27, 2007 | 04:22 PM
strickrodt70's Avatar
strickrodt70
My bike was crying for some maintenance and a good cleaning. I pulled a lot of grease and grime off this winter. I had a cracked outer sprocket cover, old oil hoses, old battery cables, dirty leaking carburator, both tires were old as dirt, rust had formed on the engine in areas where water wouldn't drain after it rained (I ride in rain...but I don't really know why), and a lot of paint had worn off or flaked of and needed painted again.
I started off by just trying to make the bike safer to ride, but you know how it goes. Once you take this apart, that get easier to get to to fix, so why not fix that too. And while you're at it.....I'm almost done now. If fact, I took a slow ride around the block today to see if anything was going to fall off or fall apart. I made it back as always....it's a good running bike.
[IMG]local://upfiles/23810/3FD12A4D64C04079891030B3B9E706D4.jpg[/IMG]
[IMG]local://upfiles/23810/A25C56BAFC1F4F13987CC318C0D38FF7.jpg[/IMG]
[IMG]local://upfiles/23810/9C640A746D44454AAB681959C019E011.jpg[/IMG]
[IMG]local://upfiles/23810/6E4C4875FA6C4F44863989B1D5194A3F.jpg[/IMG]
BigMac1200c
Jun 29, 2011 05:25 PM
noble7
Mar 2, 2010 11:03 AM
babysuge
Feb 23, 2010 10:27 AM
im_bull
Apr 26, 2007 05:14 PM
saltlick
Feb 17, 2007 02:17 AM
