Old Oct 4, 2012 | 05:33 PM
Grimes's Avatar
Grimes
6th Gear
Default ???
I recently bought my wife a 09 Sportster 1200 xl custom, originally from Cali. After I fuel it up the bike wants to stall for a few miles then it clears up and runs good till it's time to fuel up again.
I've changes gas caps, vents are open and Cali. emissions cannister seems to be open as well.
Any ideas??
Old Oct 4, 2012 | 10:17 PM
John Harper's Avatar
John Harper
Don't you have an electric fuel pump? Maybe something to do with it?
John
Old Oct 4, 2012 | 10:57 PM
SD1's Avatar
SD1
Fuel pump is a known prob. I am not sure its actually the pump, it may be the relay/fuse which isnt very well protected. The relay/fuse is under the left cover next to the battery, may have a look at that.
Old Oct 5, 2012 | 04:16 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
Here's a wild stab at it - possibly overfilling the tank and causing vent problems until you burn off that little bit of extra fuel and allowing it to vent properly. I go with this theory cause you say the problem is only right after filling up and then is good til the next fill up. full tank=problem - not full=no problem solution - don't top off the tank
Old Oct 5, 2012 | 06:01 AM
grbrown's Avatar
grbrown
Wink
You could be onto something there, good suggestion. Gas is normally stored under ground, so is cool when first filling up. However if it is sunny and hot, once in the bike's tank the gas will quickly warm up and expand, which could add to the problem.
Old Oct 5, 2012 | 10:23 AM
slimburns's Avatar
slimburns
+1 on the overfilling. I have a 48 w/ the peanut tank, so I tried to fill it just as much as I could at first... with the same sort of results... now i don't 'overfill' it and the problem stopped.
Old Oct 5, 2012 | 11:01 PM
Grimes's Avatar
Grimes
6th Gear
Default ???
Could be that relay fuse I just changed the battery and could have loosened it up.
I'll try not filling it up so full.
Old Oct 5, 2012 | 11:07 PM
wanabe's Avatar
wanabe
i have overfilled and the bike acted as you suggest... but you know when you overfill cause the excess comes spilling out.
old cat
May 30, 2019 05:19 PM
Moboy
Dec 20, 2010 12:07 AM
tmiller429
May 28, 2010 09:07 PM
Tanker2
Feb 12, 2009 02:29 PM
bertmccarrthy
Nov 6, 2007 10:27 AM
