nothing but problems...need any knowledge
Old Oct 7, 2012 | 07:02 PM
sportinit's Avatar
sportinit
1st Gear
Default nothing but problems...need any knowledge
I bought a 79 sportster project bike and had a guy build the motor. got it back and wouldnt run worth a crap. so I brought it to a reputable shop and had them go through it to make sure everything was good. they put an oil pump on it because the oil wasnt circulating. i get it back and go to test it out and after about 3 miles i hear a little backfiring and clanking in the motor(same sounds i brought it in for). so i look in oil bag and oil was low and not circulating so i took the pump out and drained the oil....there was probably a little more than a quart in the whole bike. would that cause the noise and make the pump not work properly? what should be my next step
Old Oct 7, 2012 | 07:16 PM
Irishfire1's Avatar
Irishfire1
Yes it would cause noise. Fill the oil up to the proper level and try again. Just a question, are you sure you didn't drain the primary? It usually holds a little more than a quart. If there was only a quart of engine oil I doubt you would see any in the oil tank.
thumbbuster
Oil Archive (no new posts)
Jan 1, 2019 05:51 PM
ronnie41653
Oct 23, 2013 08:48 AM
Iron_Kicker
Ironhead
15
Nov 27, 2012 12:49 AM
dohare
Jun 2, 2008 11:57 AM
My Street Glide
Aug 26, 2006 04:27 PM
