W/a DynoJet? And it's jetted such that there's no pinging/carb farts? If so - then you and your machine are a pleasant rarity.
I had a well setup (according to the A/F sniffer in the exhaust pipes) Dynojet in my '98, and pulled it out because I couldn't get more than 40MPG on the highway.
After making numerous dyno pulls, I've found that leaving the slide STOCK (don't drill the transfer port hole out in the bottom, this causes the bike to "hunt" at some part-throttle settings), slightly enrich the mixture screw, use a thinner-tapered needle (like the NOKK from the ealier EVO XLs that didn't have an accelerator pump), increase the size of the primary jet (45 is a good starting point for most stock/mildly modded XLs) will satisfy most bikes' needs.
If you experience pinging at highway-speed rollons, you may need to up the main jet as well.
Glad yours is working better than mine and most that I have personal knowledge of running the DynoJet.
It seems to run fine and the plug insulators nice and tan. I do have my idle mix at 3 1/8 (or maybe 3 1/4) which stopped the carb popping, although when cold it of course coughs a little as expected. Can't recall it pinging ever, but I'm only 165 lbs and live on the coast, so not a lot of hillclimbs.
John
Sounds to me that the bike likes your tune - and if it works, I wouldn't mess with it.
I've used both those kits and neither are worth the money and can cause some real headaches. I've found that 2 jets and a needle change do more good than those kits and it works every time. The factory spend a lot of money making the CV run right, why try and reinvent the wheel?
Sounds like you should make your own kit and sell it since yours works so well.
The "Factory" made a great carb but with the EPA Restrictions made them run like donkey doo until you modify them.
Once modified and fine tuned they perform very well & just a 1/4 turn in the right direction can make all the difference in the world.
No coughs great idle & smooth off idle acceleration.
