Balancing tires
Old Oct 19, 2012 | 08:12 PM
Von_Zipper's Avatar
Von_Zipper
Alright, I was very bored today at work and I just kept torturing Google for hours. There is no proof beads are better than liquid. That's right, you can use plain water if you live in South or antifreeze if you do not live in South.
Old Oct 19, 2012 | 08:54 PM
Gpsjr10's Avatar
Gpsjr10
I would think water would be no good for your rims. It would cause steel to rust or cast rims to corrode. Maybe inside a tube wouldn't be so bad.
Old Oct 20, 2012 | 06:37 AM
drosgarage's Avatar
drosgarage
Dyna Beads
Old Oct 20, 2012 | 07:41 AM
xFreebirdx's Avatar
xFreebirdx
Originally Posted by cripple
well im going to give dyna beads a try, thanks. do those ugly weights just pop off with a screwdriver or is there something I should do?
Use some fishing line or something like it to cut the tape and then use GooGone or WD40 to clean off the glue.......
Old Oct 20, 2012 | 04:41 PM
mrmikey32's Avatar
mrmikey32
water will corrode the rim.
Work on rims/tires for a little, and you learn this really fast.
Offroaders have been using beads for years. hell, I have even run airsoft beads
Old Oct 20, 2012 | 05:21 PM
Von_Zipper's Avatar
Von_Zipper
Yes, I have worked on tires. So I happen to know there is always plenty of moisture in compressed air we use to inflate our tires. I've used soapy water to stop slow leaks. Last time one of tires on my car ran 25k miles with soapy water in it, until it wore off. I replaced the tire, there was nothing wrong with the rim.
Old Oct 21, 2012 | 03:10 PM
woody2807's Avatar
woody2807
Stage II
xFreebirdx suggested fishing line... I have used dental floss to saw through the adhesive on badges etc.. then WD40 to remove the sticky stuff.
flyboyron
Jan 12, 2014 08:27 PM
SGT89EVO
EVO
15
Dec 13, 2011 11:32 PM
1931jamesw
May 27, 2011 02:11 PM
Scionic Wraith
Jun 10, 2010 12:48 PM
PDDGM
Wheels/Tires
Jun 29, 2009 09:38 PM
