Rigid frame/Hard tail question
Old Oct 22, 2012 | 07:37 PM
Constantine77's Avatar
Constantine77
Default Rigid frame/Hard tail question
Does lowering the rear tire pressure soften the ride a little, a lot or does it barely matter?
Old Oct 22, 2012 | 09:57 PM
Captain Smooth's Avatar
Captain Smooth
It may soften it a little bit for you. But improper tire pressure on a bike can be dangerous.
Old Oct 22, 2012 | 10:17 PM
Constantine77
Thats why I was asking. I agree that too low of a tire pressure can be dangerous.
I read in different threads that some riders lower the pressure to somewhat accomodate for the rough ride. Others mention tire expansion at higher speeds making the tire more conical/taller creating less contact with the road.
Old Oct 22, 2012 | 11:59 PM
j1mmy's Avatar
j1mmy
running low pressure helps a little, it gives you about an inch of suspension. but it also will cause fast tire wear, and can cause a tire to blow out if it is ridden that way very far(like several miles, on the highway). best thing to do is air them up, and dodge the potholes. lots of people have ridden lots of miles on a rigid frame. after you hit one or two potholes, you naturally avoid them after that.
Old Oct 23, 2012 | 07:46 AM
Constantine77
Great advice and taken well.
Full tire pressure it is.
Thank you
sampansam
Mar 8, 2019 04:00 PM
Redlegvzv
Oct 12, 2015 10:15 AM
BlockHead96
Wheels/Tires
Apr 21, 2010 12:53 PM
dope_man_21
Sep 20, 2008 12:04 AM
John TN
May 3, 2005 01:47 AM
