03 883 RR turn signal not functioning
Old Nov 12, 2012 | 03:02 PM
Rec.Rider883's Avatar
Rec.Rider883
Stage IV
Default 03 883 RR turn signal not functioning
I recently started having trouble with my right rear turn signal. The front right signal doesnt flash but the second filament lights up when i press the turn signal switch. That leads me to believe that the turn signal module is operational. I've already checked the fuses and the bulb itself to see if the contact on the bulb was bad or not. I did observe cracks that grew radially from the center of the turn signal bulb housing but I am not sure if that would cause a conflict with the operation of the signal. Any help would be appreciated.
Old Nov 12, 2012 | 05:44 PM
black2000's Avatar
black2000
1st Gear
I had the same issue on my 2000 sporty and found that the contact pionts on my rear one's where bad by having a guy i work with testing them with a mulit meter. I choose to take mine off as i didn't want to buy new one's. I don't think this really helped but just figured i let you know your not alone with the issue.
Geo rage
Electrical/Lighting/Alarm
11
Mar 24, 2013 02:21 PM
W1ldC4t
Nov 27, 2012 05:08 PM
unclerogi
Jun 16, 2012 09:13 PM
gilyoyo
Nov 1, 2010 03:07 AM
larazauk
Sep 19, 2007 06:56 AM
