Lurching problem
Old Nov 27, 2012 | 12:47 PM
NJH's Avatar
NJH
Question Lurching problem
I wonder if you guys can help me....I bought a 2009 custom a few months back (my 1st bike). I'm having trouble maintaining a speed of around 30-40 without lurching the bike. I have taken advice and practiced slow speeds and am pretty good at it now. But it feels like my bike wants to go slow or over 50mph. It came with screaming eagle exhaust-can this be contributing? Thanks--Norma
Old Nov 27, 2012 | 12:50 PM
hhkiwi's Avatar
hhkiwi
What gear are you in at 30 - 40 mph when the bike lurches?
Normally it is just a matter and shifting down one gear. Lurching often happens when you lug the engine.
Old Nov 27, 2012 | 12:53 PM
NJH's Avatar
NJH
I am in 2nd because I was lugging it in 3rd...
Old Nov 27, 2012 | 12:56 PM
JeffJA's Avatar
JeffJA
check the air filter and see if its stock or a hi-flow.
Old Nov 27, 2012 | 12:58 PM
hhkiwi's Avatar
hhkiwi
That is strange! Your bike should not lurch at 30 - 40 mph in second gear. I can comfortably do 35 - 40 mph in third...
Old Nov 27, 2012 | 01:17 PM
cHarley's Avatar
cHarley
You didn't say whether you have an 888 or 1200.
For "easy" around town riding, the Sporty motor is happiest between 2500 - 4000 RPM. Depending on which motor you have, use one of the charts below as a guideline to see what gear you should be in at a given speed to keep the RPM's in that range.
Also, how long (miles) has it been since the primary chain was adjusted?
John Harper's Avatar
John Harper
I've heard some carb bikes can lurch due to drilling out the slide vent hole and chopping the spring, but an EFI bike should be pretty smooth. Has your ECM been "flashed" with an upgraded fuel map?
+1 on checking your primary chain adjustment too.
John
Old Nov 27, 2012 | 01:56 PM
NJH's Avatar
NJH
What happens if you hit the rev limiter?
Old Nov 27, 2012 | 02:30 PM
John Harper
I think it justs cuts out power to the coil. Can't say for sure, because I don't rev my that high. I think you have to be close to 6K RPM.
John
Old Nov 27, 2012 | 02:44 PM
JeffJA's Avatar
JeffJA
my 09 did THE VERY SAME THING, it came with some V&H slip on's, i thought it only had the slip on's, till i opened the airbox and seen a K&N, i then got a power vision and did a re-flash, never had the "surging" issue again.
