Starting problems
Old Nov 30, 2012 | 10:23 AM
ole ironhead's Avatar
ole ironhead
Stage IV
Default Starting problems
I hasve a 75 ironhead that i just put a new starter and solenoid on cant start with starter button but cranks fine if you jump across the solenoid.
Old Nov 30, 2012 | 10:26 AM
1984_FXRT's Avatar
1984_FXRT
Have you done a continuity test between the handlebar button and the starter solenoid? Sounds initially like either a bad button-switch, a short between the switch and relay, or perhaps a bad starter relay.
Old Nov 30, 2012 | 12:06 PM
DOMAPOI's Avatar
DOMAPOI
Have you checked the fuse and relay? When you short the starter you are bypassing those.
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
eng23ine
Jun 18, 2013 08:30 PM
fire48
Aug 13, 2012 11:55 AM
glide1996
May 28, 2007 01:39 AM
zacjac
May 5, 2007 10:50 AM
