Mirror Vibration
Old Feb 2, 2007 | 01:45 PM
johnsonabq's Avatar
johnsonabq
Default Mirror Vibration
Anyone have ideas on how to deal with mirror vibration? Much of the time I have to drop the throttle and pull in the clutch to see what's behind me. [:@]
Anyone... anyone... Buller, anyone?
Jeff
Old Feb 2, 2007 | 01:57 PM
brauny1's Avatar
brauny1
Default RE: Mirror Vibration
Vibration a problem with an 2007??? I thought they solved that in 2004. I have a 2000 XL1200C and it don't bother me much. But I will say I have jell filled fingerless gloves help, an I wear Skeeter boots with the thick, softsoles an I just bought a Mustang seat (only cause a cat thought my stock onewas a scratch pole RIP).
Old Feb 2, 2007 | 02:02 PM
johnsonabq's Avatar
johnsonabq
I'm just referring to mirror vibration. The bike's ride is fine, I don't feel any problems with vibration. It's just that while ridingI often can't see what's in the mirrors. Hell, cruising at 70mph is sweet.
Jeff
Old Feb 2, 2007 | 02:21 PM
brauny1's Avatar
brauny1
$heet, now I'm embarrassed, got to learn to read. Mirror vs. Minor, I'll repeat that 10 times.
Tons of mirror choices out there, I bought a short, stocky stem with a high quality mirror, it helped a little. It also helps whenIsqueeze hard on the grips and pull my elbows in.
Old Feb 2, 2007 | 04:00 PM
capttawes's Avatar
capttawes
Next time you replace your grips stuff a roll of nickels, lead,piece of hvy. pipe orpretty much any weight (taped up and siliconed into each end) and your mirror vibes will settle down.
Old Feb 2, 2007 | 04:33 PM
Biker Chick's Avatar
Biker Chick
I'll try that, too! I have the same problem.
Old Feb 2, 2007 | 04:41 PM
Amy's Avatar
Amy
Same problem here as well. I am looking to buy smaller mirrors and was gonna see if that helped first.
Old Feb 2, 2007 | 04:45 PM
DaveJ's Avatar
DaveJ
ORIGINAL: Amy
Not to be picky or anything, but you have a typo in your signature.
Old Feb 2, 2007 | 04:54 PM
Hagar the Horrible's Avatar
Hagar the Horrible
is the problem with stock mirrors or aftermarket ones?
Old Feb 2, 2007 | 05:23 PM
GhostBagger's Avatar
GhostBagger
Used to have an 05 883R, no problems with mirror vibes. Maybe the different types of handlebars (or the extra engine inches)make a difference. Adding some weight at the bar ends should help.
GhostBagger.
