Lithium batteries do NOT require a tender, they do not have a natural discharge like a lead acid.
I have a really crappy habit of killing batteries, I've gone through four in about a year. As we all know with AGM batteries, once it's fully drained it's not likely to be saved. My question, essentially, is this: can I fully drain a lithium battery and re-charge it with that specific charger? Would that do any damage?
If a lithium battery is drained to below 10.5 volts it will severely damage it, possibly to the point of not being useful anymore.
However, unless you leave the lights on (while it is not running) or have some other drain on the battery (while it is not running) for an extended period, you will not have a problem with this.
Lead acid batteries in rigids and strutted bikes can have a greatly shortened life because of the vibration. Also, heat will negatively affect a lead acid battery (if the battery has been relocated in a custom build very close the engine or exhaust).
The AG batteries are NOT affected by vibration or heat.
Cool thread, thanks for posting this.. I have been on the fence to buy one of these for a while now and it looks like it's a go.. First I want one in my FXR mainly for the weight savings as I wouldn't mind losing 8 pounds or so up high on the bike..
I am looking at the Ballistic 16 cell model 500cca for my Softail as the HD AGM battery barely kicks it off at any less than a full charge because it a high compression stroker with no releases..
One thing I will say about the HD AGM battery is that it is 5 years old and still works fine probably because the bike is a daily driver around town here..
Guess it's time to open the wallet, I would like to put them in all 3 bikes..
Aside from the weight savings, I really like the size and could see making an aluminum box to fit in the battery tray to hold the smaller battery tight and create a small storage space for tools, parts, ect..
On my 1991, a tiny battery would look pretty goofy inside my exposed battery tray, not to mention trying to figure out how to secure it from the top. The Shorai is made to fit the stock battery tray? It looks like the Shorai listed for my bike weighs 4.68 lbs, my current battery is 13.6, so almost 9 pounds lighter!
John
John
Yes, we do not have them listed on our website, but we do have them in stock size.
Just PM or email us the year & model or the dimensions and CCA you want. Also which side you want the terminals on.
They're nearly identical to stock sportster battery dimensions if you purchase the recommended model (LFX21L6-BS12). The weight is nearly 10lbs lighter. They also include foam spacers to ensure a snug fit if they're smaller than your battery compartment. If you're willing to accept some risk, you can find a smaller form-factor battery which some folks have had success with on a Sportster. Mine failed rather quickly.
In regards to charging, you can use a standard low amperage trickle charger as long as it does not use a desulfication mode. "Battery Tender" brand are confirmed by the Shorai FAQ to be compatible.
As an update to my personal situation, I just fired the bike up in a 35 degree garage on the new / replacement LFX21L6-BS12. Took a few attempts since it's been idle for roughly a month (had to get some stabilizer in it for the winter), but it had no issues turning the motor.
