FuelPak + Pipe Bluing
Old Jan 9, 2013 | 12:01 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Grandpa always said if it aint broke don't fix it....Put your new tape on and ride it some more. If you are too rich, sooner or later it will act like the choke is on and start back firiong through the exhaust, then you will know you have a problem.
Old Jan 9, 2013 | 12:04 PM
Scrmnvtwins
Originally Posted by Madnss
I would disagree on always. My pipes go from black to blue to gold. It has more to do with how much heat is going threw. I understand a lean bike will be hotter. But a beefed up 1200 that's tuned and is run very hard will change all kinds of colors. And color isnt dependent on lean or rich
Hard to argue with that logic, Ive only been riding and tuning Harleys for 32 years. By the way, look at any new pipe manufacturer and their disclaimer for pipe blueing because it is directly related to your AFR....
Old Jan 9, 2013 | 12:19 PM
Madnss's Avatar
Madnss
Originally Posted by Scrmnvtwins
Blue always indicates rich / Gold Lean, much better to be too rich as engine runs cooler
I didnt disagree with your statement. I disagree with the always statement. Just because you stated you had 32 years of exp? Does that mean you know everything?
Old Jan 9, 2013 | 12:21 PM
Madnss's Avatar
Madnss
Give me any sportster with perfect afr and ill have the pipes 3 different colors in a week from beating on it, on the street and one test and tune day at the track.
Old Jan 12, 2013 | 07:27 AM
landonm11's Avatar
landonm11
ditch the fuelpak... i am planning on doing the same thing my self!
Old Jan 12, 2013 | 08:55 AM
Otter's Avatar
Otter
The fuelpak only works in open loop, you need something to richen it up in closed loop. Spend $100 and get some XIEDS, and your bike will run a lot better and cooler. It'll idle a lot better too!
Old Jan 12, 2013 | 08:56 AM
Otter's Avatar
Otter
There are several threads around that document using the two together, and they say it works really well.
VRADMAN
Touring Parts
Oct 15, 2018 11:08 PM
ryderbiker
Mar 2, 2012 09:02 AM
Garemlin
May 5, 2010 11:18 AM
Dyna2007
Jan 6, 2010 08:35 AM
