Nagging ECM question
Old Jan 12, 2013 | 10:56 AM
ib5150's Avatar
ib5150
Question Nagging ECM question
I have a question that has been nagging at me for some time, I asked my the Harley dealership here in California (a while back) if they would install Vance and Hines exhaust on my bike and they told me they could NOT do anything to the motor or exhaust that would jeopardize the Cal emissions standard here in Cal and that either I would need to install them or have it done elsewhere, so here is my question after installing the exhaust and the high flow air intake I took the bike to them to have them do the ECM download which in my understanding allows for more air and fuel to enter the motor BUT wouldn't that be jeopardizing the emissions here in Cal?? Also, what does the download do to the ECM am I correct in thinking that it is allowing more fuel into the motor to compensate for the more air the intake is allowing in??
Old Jan 12, 2013 | 11:02 AM
Scuba10jdl's Avatar
Scuba10jdl
It's a lot harder for a cop to spot an ECM flash than it is aftermarket pipes.
The download just accounts for the new airflow changes so that the stock ECM can get back into it's range of adjustment. It can only account for small changes, and sometimes after market stuff gets outside of the ECU's "window". In that case, the ECU wouldn't be able to adjust all the way to where it needs to be since it is limited to a certain range. Programming it to account for the changes moves it's "zero" line, and then it can work properly again.
Old Jan 12, 2013 | 12:05 PM
ib5150's Avatar
ib5150
ok so the motor is now compensating for the extra air from the stage 1 upgrade so that means the stage one is complete then? no tuner needed or is there another benefit for installing a tuner??
Old Jan 12, 2013 | 02:39 PM
Scuba10jdl's Avatar
Scuba10jdl
No, it's not. It tries to compensate but it can't because it only has a really small window. That's why people use tuners. If you add a Stage 1, you go outside of the window for the ECU to compensate and need to reprogram it so that it will work right again.
Old Jan 12, 2013 | 02:41 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Sort of...you have a quasi EPA compliant Stage 1, but it is still crippled because the download added more fuel to keep you at the already lean factory setting of 14.7:1
You can get the XiED that will get you running a bit richer, you will notice a nice improvement in acceleration and no more low speed hesitation.
Click HERE for details.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
kuchyyz
Exhaust System Topics
Aug 15, 2016 10:39 PM
TooTall2
Jul 10, 2016 08:45 AM
ashenfang
Sep 26, 2008 07:03 PM
Professor
Sep 4, 2007 05:50 PM
Kern
Jun 21, 2006 12:36 AM
