Changing stock pipes to vance hines
Old Jan 19, 2013 | 01:55 PM
Original Pablo's Avatar
Original Pablo
6th Gear
Default Changing stock pipes to vance hines
I want to change my stock exhaust to all black 3" vance hines slip on exhaust. Am i going to need a fuelpack as some sites suggest or am I okay with just changing exhuast and doing nothing else> I have a 2009 XL883N.
Thanks.
Old Jan 19, 2013 | 02:02 PM
Brion B's Avatar
Brion B
As long as you still have the stock air filtration system still in place you will be fine.
Old Jan 19, 2013 | 05:03 PM
Original Pablo
6th Gear
Thanks Brion.
Old Apr 23, 2013 | 12:17 AM
mr_bungle's Avatar
mr_bungle
so if i change the air filter will i need to tuned the bike
Old Apr 23, 2013 | 12:31 AM
iwantmybeerbackplease's Avatar
Yes, you will need to fix the lean condition if you add a free flowing air cleaner. Lean means, you have too much O2 in relation to fuel, which causes the engine to run hotter than it should. If you do get a tuner in the future, you should get something other than a Fuelpak. The Fuelpak is a very limited tuner. I'd consider something like a Powervision. They're expensive, over $500, but they are well worth the investment if you want your bike tuned correctly. A fuel pack will NOT give you a full tune! One cheaper option is to get some version of XIEDs for your model bike which will fix the lean condition but will not tune the bike. You will at least protect your engine from being too lean.
mconlin
Jun 18, 2015 11:03 PM
seansportster04
Mar 2, 2010 03:14 PM
SportsterPapa
Sep 22, 2009 12:57 PM
titus3:5
Dec 11, 2008 04:44 PM
70mach1
Exhaust System Topics
Jun 10, 2006 08:52 AM
