Road King Shock Lowering
Old Feb 12, 2013 | 03:23 PM
AwesomeIndeed's Avatar
AwesomeIndeed
I grabbed some 12" shocks from a Street Glide and in all honestly the rear does not sit very much higher than before. The comfort difference is night and day. I'd imagine shortening them to 10.5" wouldn't make a huge difference and would still look and ride great.
Old Feb 12, 2013 | 07:53 PM
wamps98's Avatar
wamps98
I guess I'd like more people to chime in on ride quality with 13" road king shocks with lowering blocks vs factory iron shocks..
Old Feb 12, 2013 | 09:05 PM
PanHeadRich's Avatar
PanHeadRich
I'm gonna give these RK air shocks a shot myself. In searching these threads, I've read a couple of posts saying that using lowering blocks will make for a much harsher ride. Well my bike with stock shocks & lowering blocks does ride like ****. So I removed the lowering blocks to give it a try. IMO, it rides just as bad with the blocks, then without. I honestly notice no difference at all. I was hoping it would improve the ride, but it didn't. So I'm not personally sure if there's any validity to that claim, or not. I'll try it both ways when the RK shocks arrive. Who knows, maybe if you have a good ride, then install the blocks, you'll notice the difference. I should know within the next week or two.
Old Feb 12, 2013 | 11:18 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Air shocks will ride smooth, air shocks with lowering blocks will ride smoother...but you do have to adjust the PSI. Simple physics.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Feb 13, 2013 | 08:16 AM
wamps98's Avatar
wamps98
Thanks for the responses guys. Any idea what a good psi would be for the 13" RK shocks with 3" Lowering kit. I'm 209.5 today lol, but will probably be getting close to 200 when I ride in Spring.
Old Feb 13, 2013 | 08:28 AM
Kontankerous's Avatar
Kontankerous
Not too sure, it's something you'll have to figure on your own. It's one of those subjective things. A good many of us ride the air shocks with no air simply because the sporty just isn't a heavy bike. I myself am 190lbs/6ft and ride with no air and it's comfortable as hell. + i do the unthinkable and run a spring seat AND have shocks...OH MY!
Old Feb 13, 2013 | 08:50 AM
Kushman's Avatar
Kushman
I for one have to wonder why would you use bagger shocks and especially HD ones. The "air shocks" are for heavy loads and the air is used as a preload only you are not ridding on air, at my weight of 205lbs I run from 6-12 lbs preload on a bike that weighs twice as much as my sporty. Is it because these shocks are often available due to people upgrading or something else? Would it not be easier to go with a 11" "quality" shock and drop the inch if you want. Not hating on this just curious. And yeas I know the burly is stuff is named wright as mentioned feels like struts.
Old Feb 13, 2013 | 11:31 AM
wamps98's Avatar
wamps98
DK, do your saying the rk's ride better with lowering blocks than just using the rk's by them selves
Old Feb 13, 2013 | 11:55 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Like said, you will have to experiment. I would not run 3" lowering blocks, there is not enough frame to get a 3" lowering block supported correctly.
I would get some 12" take-offs and use the 1.75" lowering block, that way you are not sacrificing stability or safety.
I think it is because it is so much less expensive, and many of us discovered a huge increase in ride comfort with the take-off air shocks.
Yes, the lowering blocks put the bottom of the shock further back on the swing arm. This increases the leverage on the shocks, making them "busier" absorbing more of the road imperfections.
When I was running 13" and no lowering blocks I was running 5 PSI for a smooth ride. When I added these 1" lowering blocks I played around with the PSI and found 18-20 PSI gave an even smoother ride than any PSI and no lowering blocks.
Old Feb 13, 2013 | 12:11 PM
Kushman's Avatar
Kushman
Thanks DK,
My brother has a Burly kit and let's just say its about the same as my rigid. I am changing the bager shocks and will look at sending them in to have them lowered and rebuilt for his bike.
Cheers
