shock help please
Old Feb 26, 2013 | 01:12 PM
mattman89's Avatar
mattman89
Default shock help please
will these air shocks fit an 05 sporty 1200c? 54565-97C thats all the info i have on them. anyone?
Old Feb 26, 2013 | 02:49 PM
DallasSportster's Avatar
DallasSportster
They should work. You might have to add some washers on the right side in order to clear the belt guard as they are a bigger diameter than your stock shocks. They will also raise your ride height slightly as they are a longer shock.
Old Feb 27, 2013 | 03:03 PM
mattman89's Avatar
mattman89
i will be buying these shockes used, is there anything i should be looking for?
Old Feb 27, 2013 | 04:59 PM
edgeofinsanity's Avatar
edgeofinsanity
Make sure they are plugged, you don't want any oil leaking out. You can change the oil, but it's kind of a pain.
They will fit with some washers or spacers, they are longer than stock and will raise your seat up. You can get back to stock height (or really close) with 1" lowering blocks. Check DK Customs, I bought the M.A.C.s Fabriaction blocks and they aren't nearly as nice as the ones from DK.
You'll also need some 1/8"NPT schrader valves, sometimes sold as "tank valves", I found mine in a hardware store with the air compressors for $3 a pair. Sometimes you can get that take off shocks with an air line kit, then you wouldn't need those valves. You'll need some kind of low volume hand pump as well. Progressive makes one, so does HD.
Old Feb 27, 2013 | 10:35 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Yes, they'll work. They are 13" and like edge said, they will be even smoother and sit a bit lower if you couple them up with a 1" set of lowering blocks.
You should be able to get a nice slightly used pair for under $100 on ebay.
I ran mine like that with the schrader valves and extra washers to clear the belt guard for a couple of years. Very nice ride.
Lowering Block Link
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
s13steve
Jan 2, 2019 11:58 AM
rhythm1978
May 9, 2017 10:43 AM
Tinmanpope
General Topics/Tech Tips
Oct 15, 2014 02:33 PM
harley2
Jan 19, 2013 10:22 AM
almega1962
Jul 26, 2012 08:22 PM
