Torque Specs
Old Mar 18, 2013 | 01:31 PM
kyhasumm's Avatar
kyhasumm
6th Gear
Default Torque Specs
I have a 2012 Nightster, Can someone please help on how many torque pounds are needed to tighten those torx bolts on the derby cover.. I heard they strip pretty easy...
Appreciate it.
Old Mar 18, 2013 | 01:48 PM
John Harper's Avatar
John Harper
I'd swap them out for regular allenheads, then tighten them gently with one hand. No Loctite on those either. If you use the torx, I believe they are T27, not T25.
John
Old Mar 18, 2013 | 01:52 PM
HOTLAP's Avatar
HOTLAP
96 inch/LBS or about 8 FT/lbs.
Make sure to use an INCH/lbs torque wrench as a FOOT/lbs wrench is not accurate down at 8 FOOT/lbs.
Old Mar 18, 2013 | 01:57 PM
Madnss's Avatar
Madnss
Put some grease or never siez on them too.
Old Mar 18, 2013 | 02:07 PM
HOTLAP's Avatar
HOTLAP
Remember if you oil or grease on the threads you have to reduce the torque used, this chart is a handy reference for the torque reduction.
http://www.raskcycle.com/techtip/webdoc14.html
Old Mar 18, 2013 | 02:10 PM
lo-rider's Avatar
lo-rider
Buy the service and parts manuals.
Old Mar 18, 2013 | 02:53 PM
kyhasumm's Avatar
kyhasumm
6th Gear
I am sure they are the T27s ... I just dont wanna push too tight... but i tend to over tighten things... ive very skeptical when it comes to bolts n stuff... I went to buy a manual today, but they are out of stock here at my local dealership ..
Old Mar 18, 2013 | 03:07 PM
lo-rider's Avatar
lo-rider
You'll have to try harder than that.
Old Mar 18, 2013 | 03:23 PM
brownfoxx1's Avatar
brownfoxx1
go to ACE hardware & buy some button-head chrome allen head screws.
measure the length of your old ones
Old Mar 18, 2013 | 05:13 PM
John Harper
That's what I'm doing whenever I have to take the derby off next time.
John
