brake light problem
Old Apr 2, 2013 | 07:38 PM
little stew's Avatar
little stew
1st Gear
Default brake light problem
My rear break light doesn't light up when I use my front or foot brake and I don't have a owners manual and not for sure what might be the problem. I have a 1995 883 sportster. I changed the light bulb so i know that is not the problem.
Old Apr 2, 2013 | 09:18 PM
883drummer's Avatar
883drummer
are ur rear breaks still working
Old Apr 2, 2013 | 10:44 PM
im's Avatar
im
Did someone change the brake lever on the handlebars or play with the hand controls on the right handlebar?
Reason: the little tit in the front brake lever (tit on switch) works opposite of what most consider normal. Out is on and in is off..The rubber tit gets broken. Button stays out which is on..most people think the brake light is broken but in reality it is ON.
Check to see if BOTH filaments are ON.
You are right the light is not the problem it is the switch...but i am guessing.
Stand in front of bike with skinny screwdriver on front brake side.
Squeeze brake lever and then with good flashlight look up into lever and press the little tit and the light will go off.
Old Apr 3, 2013 | 08:42 PM
gilmour68's Avatar
gilmour68
I agree with im, maybe your light is on all the time. I think it would be unusual for both brake switches to go at the same time - though I did have issues with each of mine at various times.
As suggested, check the front switch first.
Super Glidester
Jan 28, 2015 03:25 PM
SteveB FLH
Oct 18, 2012 04:12 PM
VirtualNorm
May 5, 2011 07:06 PM
ian
Feb 6, 2007 07:16 PM
SIDEWAYZ50
May 23, 2006 08:32 PM
